I am trying to set the timing because I put a new distributor in and it was running a little hotter than normal.
I decided to set the timing with a timing light and a vacuum gauge.
The problem is that I get the most vacuum at about 25* Before TDC (about 25 on the vacuum)
If i back it down to 16* it drops down to 20 on vacuum gauge
That sound high????
I was running it at 12" and it is running about 25% hotter on the gauge.
That sound high????
