Help with TRE search
FWP
CRS
Prescott Valley, AZ
I'd like to make a custom Tie-rod. 75 D44 uses a ES449L on the passenger side, taper goes in from the top, nut on the bottom of the knuckle, with a drop down to clear the leaf springs.
Anyone know of an application of the same style but with right hand threads? I thought it would be as easy as ES449R, but not found.
I could use 2 lefts, but adjusting tow would be a pain...
And I won't drill out the knuckle to use heims.
Tanks!
Those look correct, I'll go to the parts store today and check em out. Thanks Chris! see you in Moab.
