87k5
Registered Member
HELLO to all you ck5 wheelers!!
I am in need of a u joint but I am not sure what I need...
This is what I have,
A CUCV (M1028A3) (I did the dually conversion myself)
I have removed the 14 bolt and replaced it with a Dana70HD.
When I reinstalled the drive shaft to the rear end I noticed there is lateral play within the yoke on the rear end. I you were to turn the drive shaft to where the yoke is parallel to the ground, the u joint slides laterally within the yoke. The caps are tight within the straps but the trunnion sides left and right.
Do I need one of those conversion joints that have two different size caps on it?
Is the u joint I have the right one, or is just worn out?
Thanks,
Charles
Thanks,
Charles
