Help with year models
babyburb
1H North of Dallas
I am looking around some junk yards and trying to find a body swap donor. Here is what I want but not sure if the year models work out. I really like the square front clip like the 70s and early 80s with the two tone middle strip but I want the interior to have the fold down FLAT second row (not the fold down with 4 inches sticking up) and the fold down pop out rear seat instead of the bolt in. Is there any year models with both of these. Hopefully more than one! Shoulder straps would also be nice. Not to intrested in power windows and doors.
Current ride is 76 3/4 ton sub.
Any advise?
Thanks
Any advise?
Thanks
Well, the front clip is very different for 73-80, and 81-91. There's a tech article about all the pieces you have to swap:
http://coloradok5.com/grilleswap.shtml
Works the same both ways -- radiator support, cowl, plus the obvious pieces.
I *believe* that the flip down seat started in the mid-80's; I know it was NOT out in '77 and WAS by '85. You'd therefore have to use an 81+ body to get the flip-down seat, and then do an early front clip on it, or keep your existing one.
Since you have the '76 (i.e. early) style now,I'd say get an '81+ body, and then keep your existing front clip, replacing whatever is rusted or damaged.
-- A
Ok here is how it goes..........
73-75 -Full convertible with flat rear floorboard.
76-77 -Half cab with flat rear floorboard.
78-80 -Half cab with rear floorboard notched for rear passengers, frame also different.
I interpreted the OP as wanting to do a *Burb* body swap, not a Blazer. In rereading, however, I'm unsure. :dunno:
-- A
