help!!
txhotrod
Texas City, TX
Ok after goin through 10 diffrent set of inner seals for my d44 front end on my blazer i decied to scratch off the pretty paint and see if i could find the bom #'s. Well I found them but like everything else with this particular axle it comes up unlisted. The bom#'s are 603675 then a space and a 2 to the right of these are the #'s are the #'s 3267A E or F. I belive the second set is the date.. Is my axle realy from 1967!!!
This is my dd and was bought with a lift already on it as well as a body swap. I dont belive a word of what the guy said when i bought it he said there was match 3.73's but actually they were 2.78's and 3.08's. A month ago i replace every seal that was in the axle and upgraded to 4.56's, but these weren't replaced because they weren't in the axle to begin with. Well after the break in period I went wheelin and noticed that the oil was leakin from the tubes. I tore apart the axle and found out the seals weren't even there...If any can help me with this i would greatly apperciate it I need my truck back his is my DD.
Thanx ,
Blazerkid
This is for my son who couldn't log on
603675-2 is a 3.07 ratio Dana 44 front axle out of a 1976 half ton GM truck.
603675
DANA 44 FRONT
Year 1976
Make CHEVY
Model K5 Blazer, K10 1/2 Ton Pickup & Suburban & Panel Truck
Number of axle splines: 30 FULL
(STANDARD-pinion) FRONT
Number of cover bolts: 10
Diameter of ring gear: 8.5"
Number of ring gear bolts: 10
Pinion Shaft Diameter: 1.375"
Pinion Splines : 26
Low Case Ratio : 3.92
Tim,
Where did you find the info on the breakdown of the differential number? Just wondering where to go in the future.
