4x4shortbed
How in the H-E-double hockey sticks do you get the steering arm off the knuckle??? The thing is stuck on there, may as well be welded! It's the lifted steering arm & I need it for my Blazer, it's on a 3/4T 10 bolt. I've beat on it with a sledge hammer till I about had a heart attack to no avail. I sprayed WD-40 on it, let it sit a hour or so & that didn't work. Those little cone shaped deals are stuck in there. Currently it's been re-sprayed with WD & sitting overnight. Any suggestions?
The other thing is I need new center pins for the rear spring packs, 5/16"X4". Anyone know a place to get 'em?
Also, any tips on getting the bolts out where the front leaf bolts to the front mount? I have the nut & washer off & I was able to use the hammer to get it flush with the bracket, but now I can't get it to go any further! It has poly bushings, could they just be gripping the bolt super tight?
Thanks- John
Thanks- John
