hawkeye649 said:Ya his rig is pretty damn sick....
I wish I had bought that (I think 98) chevy 2500 350 (yes, def 350 so before it was done away with) vortec running for $500.... just slid the body inbetween a tree and a telephone pole... still had a good 14bff.....![]()
The difference between 5K and 6K is nominal if it gets me to the point where I'm competeing with a diesel.
Maybe finding a nice cummins out of a dodge is in my future.![]()
Decisions suck, I wish I had the money for one of each.![]()
Spending $5-6K for a 383 seems goofy to me.....
Since about the 60's, V8 engines have been able to produce 1HP/Cubic Inch pretty easily....(and cheaply!) As you start to increase that ratio.....(more power for a given displacement) you start buying more premium parts and the budget quickly goes into the stratosphere.
A modest 454BBC can hit your numbers a lot more easily than a 383SBC will...and if you're going to TQ numbers like 450 - 500LB/Ft, I'll even wager that the BBC will do it cheaper.
500 LB/Ft from 383 Inches is not easy or cheap.
FWIW -> I've having a 502 built for me right now (for less than the $$$ you are looking to spend), and it will probably be installed into the K5 this winter. Since you're so close you might want to look me up and I'll take you for a ride!!!
