moturbopar
Well I am finally done with one side of my blazer!!
I finished the f250 mount, 14" travel shocks, relocate shackle mount, install 7" shackles and trim up the fenders. Im not finished with the passanger side yet but can tell that the drivers side is MUCH softer! I was worried about installing the longer shackles since they are 7" long supposed to give a 1.5" lift, but when relocated like this they have only raised the front 3/4". My pinion angle only changed 1 deg. Also what do you guys think about the shackle angle does it look ok?
Thanks
I finished the f250 mount, 14" travel shocks, relocate shackle mount, install 7" shackles and trim up the fenders. Im not finished with the passanger side yet but can tell that the drivers side is MUCH softer! I was worried about installing the longer shackles since they are 7" long supposed to give a 1.5" lift, but when relocated like this they have only raised the front 3/4". My pinion angle only changed 1 deg. Also what do you guys think about the shackle angle does it look ok?Thanks
