Here ya go!
cybrfire
1 ton status
Iowa
http://diy4x.com/product.php?productid=17866&cat=0&featured=Y
Our hydraulic assist cylinder is specifically designed for our steering arms in a high steer configuration. What that means to you is this, the cylinder is of the appropriate stroke length to maximize your mounting space and clearances while preventing the cylinder and hydraulic pressure from damaging your knuckles. The cylinder itself is your steering stop. When properly adjusted with our arms, they cylinder will stop the travel just shy of the steering stops making contact. I can't think of any trail breakage that is worse than a busted steering knuckle.
1.5" bore x 4.875" stroke.
The 5/8" diameter rod is black nitride which does a much better job of resisting corrosion from road salts and calcium than your standard chromed rod.
We've topped it off with High quality QA1 rod ends.
For a limited time, we'll include the Dark Forces hat with every cylinder purchase.
Stay tuned for upcoming package deals including our extremely popular high steer tower mount and a Master cross over and high steer package.
