87shortboxguy
Registered Member
When i give my truck light gas when it is warmed up it is hesitant almost sputerring. if i slam on the gas is starts to dump gas and fall on its face and eventually starts to get moving better. Any ideas? it has a new fuel pump/distributor and all that good stuff. I don't have the kickdown cable hooked up but it never did that before... Also, is there any advantage to having my old throttle body rebuilt? i'm not sure if the gasket leaks (probably not) just curious. and if so, are there any performance upgrades for a stock throttle body? thank you!
