hey darkshadow
he he he thank you the whole system is also devastatingly bright.
i pulled my headlights and replaced each with two hologin flood lights,that each have two sepretly switched bulbs inside them. so 1 bulb became 4
the hi beams got replaced by another flood,and pointed outwardswith a checker plate bezel.
but since these are floods i was out driveing my lights a lower speeds so i HAD to add some spots. so it go 2 150w 6" whites and 2 yellow fog lights(yellow kicks ass cuts through fog and heavy snow/rain.
i also have these old driveing lights my bro had (buged to put them on) so i slaped them under the hood, so i now have work lights at all times.
all my lights are controlled here, intierly custom made box.
it has all 30amp relays wire in place, with led desplays,and push buttons for gauges and parking lights.
oh yeah if i am idleing at park and turn them all on at once the truck stumbles and almost stalls!!! LOL
just the head lights (not the spots) when turned on togeather draw 67amps!!!!!!
i also have the 12voltguys fuse panle to wire it up to. i am going to tie each output on the panle to a led then loop the grounds and have it on a switch hit the switch and it will tell you if any fuses are burnt.
oh i also have a mr16 hologin(sp?) work light mounted to my dash:pimp1:.
any more in front and my camra refused to take the pic to bright:saweet:
