Hi guys! I\'m back long enough to try and sell the remainder of my stuff.
5-13-04 UPDATE: I'm letting you guys have first shots at the parts listed below. If they don't sell by this coming weekend, I'm deleting the thread and putting it all up on eBay. Probably will fetch more dough on eBay but wanted to help the KC5 members first.
Really need garage space now and have no use for the stuff listed below. If you like something but don't like the price, PM me and we will deal. All prices do not include shipping.
10 spline 205 t-case
Has fixed yoke, splines are near new/mint condition, includes 465 adaptor, and brand spanking new coupler sleeve in box, <font color="blue">$200</font>.
400/205 combo
Out of an '86 K30, got it from KRAZIE87K5, tranny needs rebuild, t-case is excellent, slip yoke, includes adaptor, strut rod brace, 6 bolt dust cover, torque convertor, no shifter, <font color="blue">$500 </font>.
35" Trail Cutter tires
Have 3 tires, approx. 80%+ tread left, no rims, 12.5" wide by 15" rim, <font color="blue">$75 for all 3 </font>.
15x8 Ralley wheels
Have 8 rims, 8 caps, 4 rings, <font color="blue">$10 per wheel </font>.
Bare 14FF K30 housing
Perfect for those needing a direct bolt-in for the pre-'73 trucks, has the pinion support housing, axle shafts and 4.10 open carrier, no ring or pinion, <font color="blue">$100 </font>.
Bare 14FF K20 housing
Perfect for the post-'72 trucks for direct bolt-in, no ring or pinion, has pinion support carrier, no shafts, no brakes, no carrier, bearing hubs included, <font color="blue">$75 </font> .
Bare 10 bolt front housing
No ring or pinion, no carrier, no shafts, just bare housing and knuckles, <font color="blue">$50 </font>.
Front CV joint assembly
Still tight and good, shaft cut off past the weld, good for your sloppy unit, <font color="blue">$20 </font>.
'85 auto, tilt, steering column
Like title says, out of Sub, have steering wheel, still tight and no slop at all, <font color="blue">$75 </font>.
D60 rotors
Brand spanking new, never installed, have slight surface rust, paid $150 for pair, sell for <font color="blue">$100 a pair </font>.
14FF rear drums
Out of a low mile unit M1008, 3.5" x 13" type brakes, surface is very smooth and ready to bolt in, <font color="blue">$80 a pair </font>.
400/203 adaptor
Has one broken bolt in the mount hole, absolutely perfect condition other than the broken bolt, <font color="blue">$50 </font>.
465/205 adaptor
Fits the '85-'91 K&V30/3500 or any 32 spline 465 tranny, short height which rides on double hump crossmember, <font color="blue">$75 </font>.
D60 steering block
No studs, 2.5" tall, with spacer in the center of the hole, <font color="blue">$25 </font>.
3 speed/205 adaptor
Like title says, hard to find, <font color="blue">$25 </font>.
3 caliper cores
Buy these to use as cores for new ones, <font color="blue">$5 each </font>.
'81-'91 front bumper brackets
Very straight and perfect condition, good replacements for your bent ones, <font color="blue">$25 </font>.
Hitch mount
Fits pick-ups only, not sure of the class rating, <font color="blue">$40 </font>.
'77-'80 flat t-case crossmember
Like title says, <font color="blue">$25 </font>.
'81-'84 flat t-case crossmember
Like title says again, <font color="blue">$25 </font>.
'87-'91 double hump t-case crossmember
1 pc. rear cab mount crossmember
Eliminates the 2 pc. brackets, beefen up the frame flex, <font color="blue">$25 </font>.
1/2 ton caliper mount brackets
Have 5 to choose from, 2 are '71-'76, 1 is '77-'80, and 2 are '81-'91, <font color="blue">$10 each </font>.
SBC engine accessory brackets and pulleys
Came off an '80 K10, COMPLETE, every bracket to assemble a SBC into your rig, you name it, its in the box, good for those wanting to dress up your engine bay by sandblasting them and painting, <font color="blue">$40 </font>, you don't have to look around for the brackets as they are all here.
'57 p.u. hood
Like title says, perfect rust free hood, 2 small dents, perfect for restoration projects, <font color="blue">$75 </font>.
4" rear blocks with offset pins
Will relocate the axle forward slightly by approx. 1/2" or so, taper, <font color="blue">$20 </font>.
D70HD rear
This is the mother of GM axles, 4" tubes, 4.10 gears, not sure if its open or Powr Lok'd, perfect, perfect, perfect condition, low mileage unit at approx. 40K, needs absolutely nothing, complete, <font color="blue">$400 </font>.
16.5x12 Weld Racing Super Single II wheels
8 lug, approx. 10K on them, $1200 new, sell for <font color="blue">$600 </font> for all 4.
400/205 combo
15x8 Ralley wheels
D60 rotors
14FF rear drums
400/203 adaptor
465/205 adaptor
D60 steering block
3 speed/205 adaptor
3 caliper cores
Hitch mount
'57 p.u. hood
D70HD rear
