Are you a real four wheeler if you DONT own a big shiny Hi-Lift?
I got one but it is far from shiny. I have used mine for about everything else but jacking the truck up. LolAre you a real four wheeler if you DONT own a big shiny Hi-Lift?
Apparently the requirement is to buy the jack and then mount it on your hood.![]()
Right under the LED pods.
The only high jacks I ever see are on nice, clean and shiny rubicons, oh, the high jacks look the same, nice, clean and shiny
I bought one years ago. Used it twice on the trail. Once to free the truck from being high centered on the gas tank skid. The other time the truck was nosed into a ditch in the snow and tried to jack it up to free it. Both times a winch would have been better to pull the truck out of the problem.
I never carry mine anymore. I use a small bottle jack for tire changes on the trail.
Being serious oes anyone have experience with using a exhaust jack on the trail or seen one in use? I like the concept of it but not sure of the performance on the trail. If a bottle jack and a plywood base are enough for most situations I'll save my money for fuzzy dice and light bars.
https://www.amazon.com/dp/B08699DNPG/ref=cm_sw_r_cp_apa_fabc_X1HaGbRM5QYMX
Appreciate your time.
