hi steer kit
4x4_electrician
Registered Member
Montgomery, Texas
I am considering purchasing a hi steer kit for my dana 44 front, I already have ord crossover steering kit installed, is there any way i can do this without having to purchase new steering knuckles? Also have a redneck ram installed right now and wanted to know where i would mount it to in order to complete this.:confused:
Take it easy man. Alot of the regulars have Christmas stuff going on right now.
As far as your questions....
If you are running crossover already, you have the flat top knuckle that is required. You will need a different arm for both knuckles to run the hi steer. As far as the ram mount, you can build up a mount on the axle top, or you can make a mount on the spring plate. I wouldn't recommend the spring plate, but others have done it with no problems. I actually removed my hi steer because I didn't like the ram mount options I had.
I even have a set of crossover/hi steer arms for you truck, in my garage.
sorry, it seemed like it was the only way to get a response. what would you want for the arms? Also do you have any info on how the ram mounts to the spring perch?
