Mostly I think I agree with getting away from the open cleaner. I still have my original air cleaner housing with thermac system intact and maybe I need to back in that direction in some fashion. If I find some cleaver and easy way to build a stove on the driver's I'll let everyone know. Don't hold your breath. I do however think that you may be underestimating the effects of the altitude. I believe I have noticed performance gain with the open 14' filter in weather that is not hot. Also the intensity of the sun on a clear day is really, well amazing here. So, I will be looking at fabricating a dual snorkel deal. Are we all agreed that a fancy K&N filter (part number E-1500) with the stock air cleaner housing will not increase the flow as much as two snorkels? Also there is the consideration of driveing on dusty roads. Right now it looks like a used air cleaner housing goes for something like 40 bucks at the junk yard. And that's not the deep dish. I hope I find one more reasonable. Then I suppose I need to get a dremel tool too? The actual work though seems pretty staight forward and easy.
I wish some of us K5 folks living in Colorado could confirm some of this stuff.
While were are talking about heat, air and atltitude, one of the things I did to get relief from the heat soak and hard starting after say stopping at the grocery for twenty minutes and then trying to start again, was a phenolic carb spacer. That helped some for sure. Also when I switched from a Carter afb to an Edelbrock Q-jet I think that maybe I had a little less trouble with the fuel evaporation and hard starting. It seemed that way anyhow.
