EXJAY
Had this issue since I got my 88 K5 and had a little time yesterday to look into it. When I turn on my headlights all 4 lamps come on "high beams"and the high/low beam switch dosent seem to have that "click" feel/sound to it, also I get no high beam indicator on the dash (which maybe part of my no dash light issue). I removed the access panel under the column to look at the high/low beam switch. When I pull back on the wiper stalk the rod pushes down the switch all the way and moves freely. Ive tried to operate it also by hand but same result. I removed the 3 prong plug and checked the switch for operation (continuity test) and no matter which leads im on and if the wiper stalk is pulled back or not I cant get anything to ohm or short out ot eachother or ground. I also have with the lights on 12v at two of the 3 wires (tan, yellow, lt green) that plug into the high/low switch. When I remove the plug all headlights go out. Im not sure if this is how its suppost to work or not but still tring to figure out the electrical flow. Sweems like the high/low switch is stuck in the high beam position..Thoughts/ideas, help?? This is what Im going on..
http://brochures.slosh.com/index.shtml?1988 (top left corner)
