High Idel
bpgardn
Registered Member
littleton CO
Out of the blue my 89 blazer 5.7 tbi started ideling high even after it warms up.
Maybe about 1500 rpm above normal just enough to be annoying. Anyone have an idea why?
Thanks Brett
Take a close look at your vacuum lines. If it happened out of the blue, there's a real good chance something came apart somewhere.
Could be a bad idle air control valve, coolant temp sensor, vaccum leak or any number of other things
Round cylinder on the front pass side of the throttle body, has 4 wires through a square connector
