High idle activation on a TPI motor
85k5dsl
Maryland
Is there away to activate the high idle on a TPI motor to be turned off and on for crawling ? I can only find post about a high idle being a problem.
Thanks,
Wire up a switch in the cab to supply Air Conditioning "ON" input to ECM. Usually AC "ON" will increase the idle RPM an extra 100 ~ 200 RPM. If you need more than 100 ~ 200 RPM PROM RE-Programming might be an option.
dave w
