BigJohnson
I still drive my Blazer and use it to tow with but the list of things broken/wrong/needing repair is getting to be about a mile long. You know the stuff I am talking about. I am considering a buying a late model to me (2001-up) 2500 truck or suburban to tow with etc. I am getting to the point where I would enjoy something more comfortable and hopefully more reliable. Man I sound old....
My budget would be sub $7K for this and I have found some nice looking 2500 4x4 6.0 Burbs in this price range and trucks but they all have high miles 150K-200K++. What could I expect from a truck like that? I don't want something is as bad of shape as what I have. I don't have any experience with newer trucks. Everything seems to be high mileage these days so maybe they would be good for another 100K. The suburbans seem like they might be better than the trucks as most look like they haven't been used as a real work vehicle. Some of the trucks I have looked at where fleet vehicles and look like they have seen some use.
So what are my chances of getting hosed with a high mileage newer truck or burb?
the other day, the engine has never been apart other then a intake gasket replacement done under warranty and the 02 has just under 300,000 on it. Both have had water pumps go right around 250k ( super easy to replace) both also have had fuel pumps replaced. The 03 also lost an alternator and the t case took a dump around 275k ( google case rub).
. They were both used as 3/4 ton trucks were built to be used, frequently pulled trailers up to 10k and hauled loads at or slightly over factory recommendations.
the 02 has had flushes every 50k, the 03 (dads truck), he swore up and down he had the trans serviced, come to find out the first fluid change he had done was at 220 !!!!!!
