High pinion Dana 60 1978/79 Van 14ff
b454rat
Binghamton NY
I don't have to sell this, seeing if there is any serious interest in these.
Front axle is actually from an 86 Pathfinder van. Was used by a local TV station, had less than 50k on it. Perches were welded on the tubes at 36", had them moved to 32" or whatever GM is. There is no BOM number on this axle, it was super clean when I got it, and looked everywhere and could not find one. There was an "empty" spot on the housing where the perch was welded on, looked like a factory 78/79 style but no perch was cast in. 4.10 gears and open. 35 spline inners and 30 outers as a stock axle.
Axle has new u-joints, just purchases rotors, calipers and the better pads for a 3/4 ton GM, not installed yet are Blackbirds 3/4 ton brake brackets. Axle and all parts were stripped and painted with POR then with gloss black or hammertone, all new kingpin stuff except the lower plate, all new bearings/seals, has crossover arm, (not sure what brand, probly home made) two different length DREs. Has lockouts off a 78 axle that work great, just the knobs are faded. Get brakelines, some oil and grease the bearings, axle is ready to go.
Rear is from an '80 1 ton van. Has 4.09s and a Govlock, perches moved in for 1/2 and 3/4 ton trucks. Has huge drum brakes, 15" wheels with 4.25" b/s clear fine. Not sure what the WMS is, but matches the front.
$1500 for the pair, FIRM. As I said I don't have to sell these. I can ship to a Fedex Freight dock, gimme a zip and I can check.
Pics are here
http://rides.webshots.com/album/575903983YXFqRV
and a couple here
http://rides.webshots.com/album/570524761KladTP
