handloader90
Building!
A little history on this problem.
Long version:
When I fire my truck up in the morning it fires up fine jumps to about 1200 RPM and shuts off, fire it up again and it jumps to 1200 again and I gently tap the skinny pedal and it goes down to about 300 RPM or so then I barely press the pedal and get it to about 500 RPM, over the next 10-15 minutes it warms up and has a very steady idle of 750.
Truck has been running like this for a long time, never had trouble out of it (besides teaching my Wife how to fire it up
). I've been told it's carb problems, but my carb is a newer carb, floats adjusted properly and fuel air ratio is dead on, all vacuum lines are proper. So I just run it as is.
Short Version:
Truck whines/squeals very loudly if the truck hasn't warmed up and I give her a little gas. Usually goes away when she warms up. Tonight I fired the truck up after about two days of not using it. Had to throw some gas in the carb to get it to fire up and it squealed very loudly when the gas pedal was pushed. Got to driving around and it was squealing like a pig. Went away after awhile but I would like to figure this issue out.
I'm under the assumption that it's my power steering pump (it squeaks when I turn anyway) the sounds are VERY similar.
Looking for some advice.
Long version:
). I've been told it's carb problems, but my carb is a newer carb, floats adjusted properly and fuel air ratio is dead on, all vacuum lines are proper. So I just run it as is.Short Version:
