View attachment 362160 View attachment 362159 View attachment 362158 View attachment 362157 I have a pair of Diy4x high steer xover arms for gm dana 60. Flipped and reamed pitman arm tube with heims diy is asking .
639$ make me a fair offer .
Psc cylinder I believe is 8” stroke.
Psc wants 250$ make me an offer
also have psc 2wd steering box a ear broke off worked fine somebody with brazing skills may be able to repair it make me an offer if interested.
Also have a 81-91 steering box brace 75$
The steering box goes for 600$ something it’s a psc .not sure what to ask in its current conditionWhat size is the ram? 1.5, 1.75 or 2?
Steering box drilled and tapped for hydro assist? What year box?
And are you willing to separate the steering arms from the rest of the steering or are you wanting to sell it all together?
Yeah I know, I need a box with flared fittings, not the latter o-ring fittings. Ive got a 74 k5.The steering box goes for 600$ something it’s a psc .
it may be I don’t remember I got it from ord so it’s either 1.5 or 1.75Yeah I know, I need a box with flared fittings, not the latter o-ring fittings. Ive got a 74 k5.
Was hoping the ram size was a 1.5, 2in bore is to big for me since I still drive it on the street.
Thanks anyways! Good luck with the sale.
Yes it does ,Bought directly from psc this is a psc unit.Does it have the 2 hydro-assist fittings on the side of the box for hoses directly from PSC, or did you tap for the assist?
you can run the newer bubble oring box in your older k5. You need to swap the pressure fitting in the steering pump (very easy, direct swap) and the return line is just camped on, also easy swap. Then you can run the newer bubble o-ring lines. I ran a ‘74 psc box in my ‘88 k5 back in the day and worked perfectly, no issues. Its definitely do-able. I think i had a thread about it maybe 10years ago, but cant seem to find it.
All are gone except high steer arms !
Did you see they are drilled for a 3/4 bolt I used heims but I’m pretty sure they offer an insert .What do you want for the arms?
