Scott, somewhere I saw an orbital valve that had threaded stubs on both sides and that gave me the idea to mount the valve to the body up by the column and then shorten a shaft to fit between the valve and gear box. This way if a hose goes out or something, you'd still have steering capabilities with the manual setup.You are contradicting yourself here. Full Hydro means no more mechanical linkage after the steering shaft. A full hydro system uses a orbital valve in place of the factory steering box and the only connection is the steering shaft from the column to control fluid flow through the 4 hydraulic hoses which attach to the pump and ram. Like others have said i think you need to keep the orbital portion of the stock system and replace the ram with a PSC ram and make whatever modifcations neccesary to the ram to limit travel (if needed). Dodge did use a saginaw steering box bolted to an adapter plate which bolted to the frame like someone else here already said so that would be an option on how to mount a true FULL HYDRO orbital valve WITHOUT modifying the frame one bit. Once an orbital valve is in place of the stock steering box the rest is easy.
