The oil pan on the 454 I'm swapping into the crew cab got a good size dent in it when the donor truck got blown off the jack stands. I can probably hammer the dent out, but I'm never one to pass up an excuse to upgrade. I was thinking about putting in a larger oil pan.
Milodon lists a 7qt oil pan (truck pan is 6qt factory) that looks intriguing. They have it listed under "Off Road Truck Oil Pans". http://www.milodon.com/oil-pans/off-road-oil-pans-chevy.asp
I'm a little concerned if a deeper pan, 3/4" to be precise, would cause any clearance issues. Looking at the images, it seems like that Milodon pan would actually have more clearance for the engine cross member than the factory truck pan does.
I am curious on thoughts/experiences with using a larger oil pan.
