hitch bolt size???
RootBreaker
3/4 ton status
Williamstown, NJ USA
Ok so dont know if you remember my $30 score..
well I just got a drill bit and started drilling.
So busy that I only got 2 holes in the frame and reamed all 6 holes on the hitch bigger...
now that is the kicker..
what size bolts do you have holding on your hitch?
I bought 9/16 bolts.. they are huge.. and got a 5/8 drill bit..... however I dont have a drill big enough to fit the bit... the drill extended all the way out allows the bit to fit... well used to... but now it is stripped... drill is still fine and works great but the bit wont work on it anymore...
so how big is too big? when you got someone tugging on your hitch you want it to stay there...
so what size bolts do you have on it? also yes I used grade 8...
