Looking for some information on getting a Holley four barrel TBI running on a GM TBI system.
First problem I see is in reading the Holley manual the front two injectors need to run at idle and low RPM with rear injectors off. I have no idea how to do this with a 1227747 type ECM or if it's possible.
Or can I run all injectors? Right now they are firing right front left rear, left front right rear. Holley manual states the front two have to fire at idle and low rpm or it will not run properly.
System is on a built 440 Mopar engine and the system was bought aftermarket but has never run. Chip was nothing more than stock 454 TBI. I can burn chips and tune the engine once running but wondering if anyone has had a four barrel Holley TBI experience and noticed if the injectors are all firing at the same time. I guess there is a progressive linkage and a simultaneous linkage. Seems the Holley ECM has adjustments for this.
geez we were all wishing we took electronics classes just to keep up with electronic ignition...
