1985K5Blazer305
Registered Member
Hello, a friend of mine gave me a relatively new Street Warrior that had been collecting dust in a shed for some years and needed a rebuild. Cleaned, rebuilt, and installed, the Holley was dumping fuel from the primaries. 350 sbc wouldn't idle and was running on 6, headers for cylinders 1 & 2 were cold and the plugs were wet and dripping in fuel. At "idle," fuel was showering out of the primaries and from what I understand you shouldn't see liquid fuel pouring out as it should be atomized. To preface, this motor ran smoothly on a quadrajunk prior and has new distributor, plugs, and wires, all of which are confirmed to be sparking.
First thought was to check float heights. With the sight hole removed, turned the needle & seat until fuel just barely started to leak out of the hole. No luck. Initially set the floats to be parallel with the bowl when inverted.
Next, stuck/not sealing needle? With the primary bowl removed, the needle moves without restriction and falls back down under its own weight. To check sealing with the seat, I blew air through the bowl inlet and lightly closed the needle with my finger, and no air got past the needle.
Pump providing excessive pressure? With the quadrajunk still on, I tested the pump and saw consistent 5-6 psi at idle and rpm.
Bad power valve? The valve that came with the Holley had a lot of play and looseness to it. With this power valve the primaries were showering fuel at idle. So I installed a new power valve and now the primaries drip at idle and shower at rpm (see video).
I've played with the air/fuel mixture screws within the ranges 0.75-2.5 turns out but no avail. I will mention that the car would not start with the screws fully in. Any carb tips are appreciated as this is my first rebuild. The carb is just running extremely rich, fouling plugs, and smoking out the tailpipes. Not sure what else there is to touch or adjust?
Specs: 80457-3 Holley, 64 jets, 110 needle and seat
Showering Primaries Video Link:
Thanks in Advance
Thanks in Advance
