Holley carb ID?
gravdigr
Tyrone, PA
Is there an easy way to ID an unknown carb? I got an 86 blazer and it has a holley carb (I know because the side of the carb has holley written on it). Is there a way to ID exactly what it is? It has 2 fuel feed lines going to the bowls so I'm guessing it's a double pumper but that is a guess since I know nothing about holley carbs. The Blazer has a 305 in it and I think the Holley is too big. I was thinking of hitting the salvage yard and snagging a quadrajet to rebuild, I'm too poor for TBI /forums/images/graemlins/deal.gif
There will be a number stamped on the choke horn. You can then go to holley.com and look it up and see what size it is.
2 fuel feed lines does not mean a double pumper
2 accelerator pumps means it is a double pumper
the 4150 comment is in regards to the model of the carb
4150 means a typical holley that has 2 metering blocks
if it has a primary metering block and no secondary metering block then it is a model 4160
as mentioned above get the list number from the choke horn and look it up HERE at Holley's website
it isnt a good offroad carb as there is nothing that can be done to make it climb without flooding out
