badmix
I posted about my K5 w/ 570cfm Street avenger. It was having a problem off the line. I would push the gas easily and then it would fall on its face and almost stall, in some cases it would stall. This made for dangerous driving, esp. pulling out in traffic.
I had replaced the power valve but that didnt help anything. I decided to "re-tune" my truck and carb. I set my timing from 4* (factory) up to 7* and then adjusted the carb a/f mix per my vacuum gauge and got around 18hg on the gauge. Took truck for drive and it still fell on its face. hmm.
so, I decided to adjust the lil pump lever on the front part of the carb. There is a sping loaded screw. I adjusted the nut DOWN a full couple turns. This actually made the problem worse. hmm. So, I moved the nut UP about 2 turns past stock and this made a world of difference. There is almost no stalling or hesitation now.
Thought id share.
Thought id share.
