Hey guys I'm messing with my holley 600 vac secondary on my truck. I have a wideband hooked up to help tune this beast. I have it pretty close and I feel like I'm on the verge of it being good enough, my issue is the carb goes lean past half throttle then richens back up as the revs climb, I have identified this as a combination of a few things. My accel pump circuit consists of 37 squirter, hollow screw and green cam on hole 1. I tried 2 but it seems to be happier on 1.
I think I am fighting the duration of when the power valve opens up 10.5 and when the pump shot runs out. That time is where it goes lean. That time can vary depending on load and gear so it's much worse in high gear than in low.
I decided on my power valve based on the assumption I need the fuel sooner to help compensate for time of pump discharge, I have changed cam sand have gone all the way down to a 25 and it likes more fuel sooner but I think I may have to go to the larger 50cc pump setup to have it cover the transition even longer.
I have 62 jets in the main and the rear plate is oem for the 1850-2
At wot I am getting mid 12-13s on Afr and cruising depending on the throttle position I am anywhere from 11 on really low opening like 1/4 or less and 13-14 1/4 or more but this is steady state cruise.
So basically my main question is should I have to go to a bigger pump or am I missing something? I don't want to jet it way up and kill the possibility of much better mpg and better midrange tq...
