Truckin13
Registered Member
I was given a brand new Holley mechanical fuel pump today, I want to install it on my blazer with a 350. when I looked closer I noticed that my stock pump has 3 lines, I'm guessing an inlet an outlet to the carb and a return line to the fuel tank. They Holley only has an inlet and outlet. can I block off the return line to my tank and call it a day or is there more I need to do to run this pump?
..turned out to be some hot rod racing version and his Q-jet couldn't handle the pressure..
