Holley performance TBI
Keitha
Costa Mesa, CA
$250
For Sale: Holley TBI unit. This has been sitting in my garage for a few years, but worked perfectly last time it was used. I figured I would re-install it at some point, but just never got around to it.
This one has adjustable fuel pressure regulator and the newer style improved injectors.
"Holley designed these throttle bodies with all relevant emission provisions and hook–ups for a true 50–State legal installation. They are engineered for a “bolt–on” installation on stock factory Manifolds for the applications cataloged. The two barrel throttle replacement bodies are considered to be the functional equivalent of the original equipment throttle body and, as such, are considered to be 50–State legal. Therefore, the C.A.R.B. E.O. number is not required. "
Features
  • Direct Replacement For OE Units
  • 2 in. Throttle Bore
  • 42% Area Increase Over Stock TBI
  • Including Air Distribution Ring
  • Increased Torque and Horsepower up to 25%
  • 50 State Legal
does that connector work with the factory harness?
The IAC defenitly will. The Throttle Position Sensor had 2 different styles from the factory. If you have the one with inline pins, then yes. If not, then it is an easy cut and splice of the factory connector.
