HI Holley Truck Avenger 770 cfm
HI truck
Registered Member
Maui, Hawaii
Really nice used carb. Got it a while back as part of a project truck, never used it, so cant say much about it, but it will more than likely need a basic rebuild. From the looks it seems hardly used. Dichromate very nice, and overall very clean. Has a QFT adjustable secondary module. Electric choke. Has a -6 straight fuel inlet, and I dont have the factory push on banjo. No guarantees on it since I have never used it or even taken it apart. All I can say is fellow I got it from was using it until truck got pulled apart.
$250 shipped USPS
Thanks for looking20210808_160609.jpg20210808_160820.jpg20210808_160843.jpg20210808_160855.jpg20210808_160917.jpg20210808_160928.jpg
Nice Carb!!
Is it missing the two center screws on the throttle plate ? just asking.. can't remember if there's supposed to be screws in there or not.
I tried looking in and also felt all the way into those holes with a pick and didnt feel any threads, so I dont think anything goes into there.
On a side note...I did notice that the carbs linkage arm has been modified for some reason, but I think unless you are running some sort of stock linkage, shouldnt be a problem. Heres some 20210809_082515.jpg20210809_082616.jpg20210809_092049.jpgpics...sorry but I never really checked the carb out until now, only glanced at it, havent cleaned it or anything, what you see is how I originally got it years ago.
I'm now thinking those holes are probably some type of vacuum signal or bleed holes if they aren't threaded.
Looks like the previous owner cut the linkage for air cleaner clearance... unless the carb is going on a Ford with a kickdown rod for the transmission that missing hole shouldn't be a problem. I think that's what its used for...
