Yep...finally. I don't know how long it's going to take, or where it will lead. But I figure I'll get in on the build thread action too.
So yesterday I got the K5 home after a year of it sitting in TN. Today I started pulling all the crap out of it and removed the rear seat and spare tire. I then pulled up the rear rubber floor mat and insulation to see what the damage was. I didn't suspect very much. I was wrong...
So here it is...
Back seat and spare tire removed...
Here you can see a little rust poking through... No idea when that got there.
Here's where it starts getting bad...
...and this is the front edge of the rear floor...
So... I'm not sure which way to proceed. My plan was simple, replace or rebuild the rear axle, regear the front, replace the t-case and cam and DD for a while. But now with the rust, I'm not so sure.
Should I go ahead and replace the floor while the rear axle and gas tank is out? (From full to empty is like 16-18 gallons, so I assume the sending unit needs to be replaced, plus I don't want to weld while it's in there)
Mostly, I learn by doing. But is mig-welding something I should leave to a pro, or at least someone with more experience?
I have yet to remove the front seat and pull up the mat to see if it's equally bad up there. Something tells me it will be. I do realize that it could be much worse, and I've seen it. It's just not something I was expecting to tackle on my own truck.
I anxiously await input from you all!
So here it is...
