Holy crap!! Wheeeeee!!
ChevyCaGal
3/4 ton status
Sacramento, CA USA
Oh crap.... I am going to be buying these....
Dana 60 front
4.56 welded
35 spline big inner shafts
New Spice 35 spline outer shafts
New 35 spline Spicer drive flanges
New axle joints
New 1410 spicer yoke with u bolts
Fresh kingpin seals and plastic bushings
All seals in good shape
1.25 od .313 wall DOM tie rod with New 1 Ton tie rod ends
New 2.5x8 Hydro Cylinder installed on axle/tie rod
Brakes ground to clear 15 inch wheel with 3.5 bs
14 Bolt rear
4.56 detroit
New 1410 Spicer yoke with u bolts
TSM disk brakes with caddy calipers with ebrake
He's swapping in though an open carrier up front.... oh man I about peed myself when I found out yes, I can get them I have saved enough money up. My mom was supposed to help me but changed her mind on the deal! Now I need to plan how to get it home and what I need to buy to do my lift.... ahhhh the pressure, but it's a good pressure!! /forums/images/graemlins/smile.gif
wow, that sounds sweet, 14 bolt, with a locker, awsome, good luck putt'n it all in, and could you spare me the 10 bolt axle's, i could use spares /forums/images/icons/wink.gif. and that dana 60 front indistructable, and i think its all incretible. so good luck, and happy trails /forums/images/icons/wink.gif.
I hate you! no I don't. Wow, good score!!! /forums/images/icons/shocked.gif Move over UAV.
tom
WOW!!! I'm <font color="green"> </font color> green <font color="black"> </font color> with envy. Congradulations, have fun with the install /forums/images/icons/grin.gif
I hate you
You could weld the rear and not have to spend 300 on a detroit /forums/images/icons/grin.gif
wow...looks like you hit the MOTHER loud!! /forums/images/icons/tongue.gif good deal!! /forums/images/icons/grin.gif
Yeah, they are sweet axles, but I will be paying my mom back forever (but hey she doesn't charge me interest and I can do stuff like fix her car and she needs some plumbing replaced, and I happen to do that so I can work it off that way)... but the price is a 1/3 less then Boyce for the same thing, so I think I did well. It's the shipping that sucks price wise, but hey it's only $200 more then if I buy a set and rebuild them myself with the parts I need for disc brakes and so on.... So I'm happy... /forums/images/icons/smile.gif
great score!
that ride of yours is steppin up to worry free status
Yeah if only I had a different t-case I'd be happy because my tranny despite being a 700R4 is nice.
But anyhow.... yeah I got some 38.5" tires waiting for rims, and know basically what I want in the rear for a lift and flex (like Rene's 57" Ford springs, but I am still trying to figure out how to keep it at 6" height but avoid body lift).... it's now the front... no clue there... what would you suggest?
kind of a cop out answer but...
aftermarket 2" lift springs for the ford??? or a taller flip like Borrego's deal
I like the ford 57 front idea I just wish tRusty would get on it so I can see the pitfalls
I am tempted to get my lil brothers stock 1/2 ton dragged over here so I can do the swap just to check it out
he would most likely be pissed if I pulled the springs from his Bronco to shove under the front of his wreck while he was on a trip to Cali
<font color="green">ENVY</font color>
Not knocking your decision but do you think drive flanges and a welded diff might be a little hard to steer though...
</font><blockquote><font class="small">In reply to:</font><hr />
[/ QUOTE ]
/forums/images/icons/grin.gif I was thinkin the same thing at first
nicceeeee.i wish my mom was rich so i could buy all that stuff.then my truck would be mostly done. /forums/images/icons/laugh.gif .next get her to buy ya some rockwells or unimogs.haha.now that would be the ultamate loan.
Cool, lucky you!
Only thing I would say is that the 2.5" ram is too big. It will be very slow steering. My 2" ram is too slow and makes "panic steer" situations much more panicy at times, especially at idle when fluid flow volume is limited...
Also, I would get some lockout hubs and carry the flanges as spares. Then you could put a locker in the front. /forums/images/icons/laugh.gif
Anyway, congrats!
I have to agree on the ram. You will be better off with a smaller one. Also the welded front is fine but use lockout hubs instead of the flange. With the lockout you can unlock one to make a tight turn easier. Just a word of caution on a welded front, if you wheel it hard you will bust parts eventually. If you are not balls to the wall with it you will be fine. /forums/images/icons/cool.gif Roger has a welded pumpkin that I am probably going to through in mine when I do the 35 spline outers. /forums/images/icons/shocked.gif
Hey thats great steph /forums/images/icons/smile.gif Decissions decissions... Too bad for you, you have to make all of those plans now. What a bummer /forums/images/icons/wink.gif
