Ok, I have been scouring the inter webs trying to figure out a way to build a tube bender that’s capable of 180° bends on 1 3/4 DOM.
Here are some plans I am planning to build off of after I finish my fence. I believe you can use pro tools or JD2 dies.
Here are some photos of these home brewed benders. Bases and stanchions are usually made from 3/16-1/4” 2x2 square tubing. The swing made from 3”x1/2” plate. Harbor freight air over hydraulic cylinder.
I should be able to build this bender for under $1000 and it will be as strong as whatever die I put in it.
Here are the plans:
Here are the plans:
