Home made rear bumpers
BLZN4FN
Englewood Colorado
Looking for pics or some kinda of design of your home made rear bumpers that will fit a K5.
I just cant bring myself to pay 350-450 for a rear bumper
imagine anything.
draw it.
build it.
i like simple stuff built out of square or rectangle tube, but some guys like to go all fancy-fanse with round tube. that's too much work for me.
do what you want.
Hey Bo,
there was a kid on the board that mocked his bumpers up using cardboard first then laid out the pattern and built from there. I thought it was a great idea, might try that.
Hey, here is a picture of the bumper that I am working on right now. Hope this works(the picture). I still have to figure out a latch system of some sort. I hope the grade 8 bolt will hold too.
Is the grade 8 bolt your hinge? :eek1: Might need to rethink that.....
Not sure that will hold up, what size tire you planning to run?
I really like that style of tire rack. Would like to build something similar for my rig. Needs to accomodate a 37 inch tall spare though...
This is a fellow CK5er that is on this website, this is his write up.
The rear is 2x4 and 2x2 3/16 with 10 guage sheet metal. The tire carrier is 2x4 3/16 held on with a 1" x 10" grade 8. The bolt has 2 contact points and passes through 4 sections of the 3/16. There is a grade 8 nut welded in near the bottom. I also ran a seam down the path so that the bolt threads all the way down and used flanged bronze bushings to keep things smooth. The other side is a 9/16 grade 8 and another nut welded in.
I was just going off of this, so I don't know what to do if you guys say it won't work.:doah:
That's mine. There are 2 contact points for the bolt and it works great. I have a 37 inch spare and 10 gallons of gas back there 24/7.
Big 3/8 inch think diamond plate all arc welded together and ground smooth on the edges modeled after a regular chevy bumper with the big notch out in the center for the licence plate and it has a big pintle hitch used to pull dozers.
