home made shackle filp??
K-5kid
el paso tx
i am thinking about doing a shackle flip on my 73. does anyone have any tips on how to do it. I am doing it to get rid of the 4inch blocks and i wont be doing any towing. and pros or cons on this would be great
Need a flash for that pic. The background is too dark to see the frame and shackle.
Why does everyone use the front hangers? Because you could move them forward or backward when you put them on? I think it would be easier to just cut a hole in you stock hanger and brace it up, thats how im going to do it anyway.
i tried the cut thru setup. flipped it back after two days. horrible shackle angle ,rode like a dump truck. tried removing leaves, didnt help.
its worth it to get a ORD flip or use a front bracket. tho i think the ORD flip should have a better angle. i guess its ok for an all around rig, works good for towing and such. i want to move mine forward a bit and maybe run a longer shackle.
i cut my rear hanger and stuffed the shackle through it.... works fine. i may get some longer shackles. but its not needed
i did homemade flip but used 56'' and longer shackles 8.25 hole to hole . great angle.7''lift.
For real heavy offroad use, how much strength is cutting all that material out going to leave, even if you reinforce it? How many have broken shackles and shackle hangers?
I did the "cut a hole" trick and don't like it. I have 5.5" lift rear springs and there isn't anywhere close to enough room inside the shackle hole for the shackle to move when the spring compresses. I will use some front hangers from a 2 wheel drive that I scapped today with longer shackles.
If you have the cut a hole method already just continue it. Reinforce the shackle mount with some angle iron or C channel and gusset it all up. Then cut the rest of the bottom of the shackle out.
That is how az-k5 did his shackle flip. It works great sofar and he beats the hell out of it. He has since swapped to 56's out back and that is all good too.
Collapsing a shackle isn't that hard to do if you beat on your truck hard. Making some beefy replacement shackles isn't terribly hard and they will last way longer then a stock shackle.
Harley
Yes, thats how I was going to do it. Make it nice and reinforced, and just make the hole as big as it needed to be.
I did the cut through method three years ago, works fine, no reinforcement. I was thinking of reinforcing it, just haven't got around to it. With stock springs there is plenty of room for shackle movement. Longer shackles, that would make a bad pinion angle even worse, would really need to move the spring perches at that point. As it is now my pinion angle is about perfect for a c/v shaft...too bad I don't have one :crazy:
__________________
'77 K5, Warn M8000, 402/350/203, 44/14bff, 4"/36" Irok's
http://www.krazyk5.com
http://community.webshots.com/user/trcksr4me
http://community.webshots.com/user/trcksr4me2
so would it change my pinion angle enought to need a new drive line or can i keep the one i have
You should be able to use the one you have but degree shims or cutting and rewelding your pads to the correct angle may be necessary. You may also have to lengthen the driveshaft.
If it rode like a dump truck, your shackle was probably hitting the bracket. Was this with stock springs or aftermarket? I did it with stock rear springs and the shackle angle is really good. The ride is also good.
Like already said, need to shim it at the very least, and probably will need a longer driveline, mine was 2" longer than stock and was about right(also have zero rates). I had 1.5 degree shims in mine, wasn't enough. I need to reshim it at some point, took mine out when I swapped springs. I think I will get steel shims and bolt them into the spring pack the next time around.
