Home making a rear driveshaft...
PsychoticDeadGuy
Fairfield, California
could i go pull a front driveshaft for the CV part and put it on my rear driveshaft like this
or will it not work? do i need to get it done professionally? are the front u-joints the s-44 style or are they 1310?
i just wanted to add the CV part. I could cut and weld it if i needed to. i would then have to take it down to get it balanced. so, will just the CV part work with my 1350 u-joint driveshaft if i used conversion u-joints?
If you use conversion u-joints, anything is possible. You will be adding length though, so the shaft will need to be shortened.
I may be wrong, but isn't the yoke part of the CV joint? I don't know if you can find a front slip yoke driveshaft.
Lengthen the wheelbase with what, zerorates? I guess that would work.
I don't know about doing it that way though. It looks like it would add roughly 3" in length to the shaft. You really want to run a 3" zero rate.
I had to make a new shaft for the wife's Tahoe. What I did was cut an old shaft on the end that didn't have any balancing weights on it and welded it up to the new length. Not getting any vibes out of it and it's been 6 months.
i think i asked the same thing b4.. and outta all the mixed answers i got no.. who knows though..
its not tha simple. you can't take the H yoke off a CV and put in using regular yokes and expect it to last. the yoke on the driveshaft and the slip yoke must have a centering ball and cup. if you don't have these, it will not split the angle between the two ujionts and will vibrate horibly.
also you can't use a conversion ujoint on these. the other yoke must fit inside the H yoke. you can see somewhat in the pic. with a conversion joint, the driveshaft joint is larger and won't fit inside. and won't even let it rotate at an angle.
I'm not sure i understand what you are doing.... shops have a ballancer to true drivershafts
Would the front driveshaft (which would be a smaller diameter than your rear shaft to begin with) have enough angle in the cv joint before it maxes out? You would have to do some modifying. I just got my shaft from HAD and that cv joint is huge and has tons of angle. I believe its a 32* cv. I'm not running it at that with a 4 inch lift but depending on how much angle you have I believe you should check out to see if that cv joint will be sufficient for your rear driveshaft angle.
What if you took the slip yoke part from the rear drive shaft and cut it and turned it down and then made a adapter plate that you weld together to the slip-yoke. Then you could just bolt the front CV part together with the yoke, and then cut the "tube", adjust the lenght and weld it back together. Then you won't have the problem with the U-joints and balls and springs cause all that will be left untouched.
What do you think? Because I also have a front drive shaft lying around... ;)
i am just trying to make my rear driveshaft a CV style so i have a little more angle. I am running a 5-6" lift and want to keep my u-joints alive for a while. all i would be using from the front driveshaft would be the CV part. that is it. and put that inbetween my slip yoke and my driveshaft to get a little more length and angle. my driveshaft is new and i dont want to scrap it and get an all new one made so i am throwing out ideas to help with the angle at my t-case. ive already lowered my t-case 1.5" and i want to tuck it up as much as i can without blowing up u-joints.
The answer to your question is NO. Somebody gave you a long answer, but I don't think you got it.
The drive shaft in the pic you show us has a slip yoke in it. That is part of the CV joint. The CV joint in that pic is more than what you have a cir. around.
