My 78 has the striker pins at each hinge, plus a bracket with a 3rd striker pin that extends up into this hole in the hood.Exactly. I saw a pic of one, thought I saved it.
It looks to be a stout 3/16 or 1/4 thick piece.
I have the bolt that goes into it, but just sheet in the hood reciever.
Keeps it from decapitating everyone to death.
The 81 and up trucks have fingers near the hinges that catch on the cowl in an accident, forcing the hood to buckle rather than sliding back into the cab like a Ginsu....
I'll tag @kennyw ...
Bend your freshly painted hood as you go to close it and think about what you said again.Beginning around '78 or so they starting putting a third bold/stud there attached to a plate to keep the hood from coming into the cab and potentially decapitating the passenger and driver. The other two bolts, one on each of the far corners of the cowl, that stick up also serve as part of this safety feature. I'm in the process of grafting these over to my '88 on my build page since I'm doing a 73-80 front end swap. This safety feature is further backed up by the "weak point" in the hood that people complain about so much on the 73-80 hoods. The hood is designed to buckle/crumple there upon a collision. It blows my mind that the aftermarket thinks those hood braces are a good idea, clearly they don't know why the hood is designed to crumple there or don't care.
I know the design isn't the best, but for reference, I do have a '79 GMC Jimmy that's never seen oil in the hinges and the hood is in great shape. It's been through one paint job too. Opened and closed it two weeks ago. I never knew the hood fold up was a problem until I kept seeing it on the FB and the internet. My dad bought it new in '78 and he still drives it btw. That being said, it would take a solid hit from anything modern to really do any damage. Still though, when I get my front end swap done I will not be putting the braces on it. I am going with Wamrods instead of the springs, but the real thing is (and the Barrett Jackson guy probably didn't know this) that even a new hood hinge probably needs to be worked a little once installed and probably oiled a little. There's a fantastic YouTube video from Brother's of all people where they talk about this on fresh painted 73-80 squares. David Welch sets all the gaps on a '77 Blazer and it's very informative.Bend your freshly painted hood as you go to close it and think aboIut what you said again.
They may have wanted the hood to fold up on impact, but what they didn’t factor in is the horrible hood hinge/spring that binds up and allows you to find that designed in weak spot when you attempt to close the hood.
I say that knowing 99% here know how to push down and back on the hood prior to pulling it down and avoid bending the hood. But heaven forbid someone that doesn’t know try to close the hood for you. I think it was a worker at a Barrett-Jackson auction last year that kinked a hood on a custom squarebody on live tv. It was horrible to watch.
If had an early square I’d put the braces on in a heartbeat. If I get in a wreck that is bad enough to fold the hood the whole truck wiped anyway. Besides there is enough mass compared to modern stuff it’s going to take a hell of a hit regardless.
It’s all good info. Though most here aren’t the precise panel gap sort. I can appreciate those that strive for it though.I know the design isn't the best, but for reference, I do have a '79 GMC Jimmy that's never seen oil in the hinges and the hood is in great shape. It's been through one paint job too. Opened and closed it two weeks ago. I never knew the hood fold up was a problem until I kept seeing it on the FB and the internet. My dad bought it new in '78 and he still drives it btw. That being said, it would take a solid hit from anything modern to really do any damage. Still though, when I get my front end swap done I will not be putting the braces on it. I am going with Wamrods instead of the springs, but the real thing is (and the Barrett Jackson guy probably didn't know this) that even a new hood hinge probably needs to be worked a little once installed and probably oiled a little. There's a fantastic YouTube video from Brother's of all people where they talk about this on fresh painted 73-80 squares. David Welch sets all the gaps on a '77 Blazer and it's very informative.
@kennyw would be your best bet on here. I asked him about these about a month or so ago and he didn't have any, but I decided I'm not going to bother with them. Another place would be New Boyz Squarebody Rescue. Also, I laughed extremely hard at @500$k5 comment. If there's not a already a previous owner screwups thread here on CK5 there needs to be. I bet every one of us could write a book.Lol
So no one has that doubler they want to get rid of?
