NEK5
3/4 ton status
What does it involve? Tried a search, but didn`t find much. I`m putting a 14bsf from an 84 Suburban into my 90 Blazer. I noticed that the axle I got had the ebrake cables on them. These are still good right? (is this what they should look like?) There`s one coming off of each drum.
So I took a look under my Blazer to see how they hooked up, and I`m not quite sure how it does. This is what I see under my truck:
The bottom cable comes from the drivers side drum, connects to like a junction thing, then continues to go to the front of the truck. The other cable, as you can see, goes into a section of thread. I`m a newbie to brakes, for the most part, so I`m not quite sure how these hook up.
Thanks in advance guys!
