cabledawg
Secret Squirrel
I believe it's too long. Engine mount or exhaust obstruction. Dont have mine in front of me to find out.
So your thinking of putting the small A/C down to the old emmissions spot and put the big one up top?
It may be easier to just make mounts?
Ok, I finally was able to identify the compressor that my 6.2L diesel has on it right now, it is either an HR6 or DR6 (same body, different internals), can a guy remove that compressor and bolt an A6 straight in? My AC is totally in-op, and the truck has v-belts in it right now. Length is of no issue for my diesel as the AC-pump sits up on the driver's side above the valve cover, I've got all the way back to the firewall to mount it.
I'm planning to go get myself a compressor as soon as the weather clears up a bit, maybe this Saturday afternoon. Lookin' forward to having onboard air!
So, the big compressor I have in my 86 with the non-op AC could be converted to onboard air without the need for an oiling system?
How does a guy fill / empty the sump on the pump?
He probably had another type compressor. The one we are discussing has oil in it and does not need an external oiler. Like the York.a guy i know did this to his jeep. all he does is just spray some wd-40 into the intake every other time you use and it keeps it oiled. i didnt know how easy this was to do. everytime i heard onboard air i thought you guys were buying some aftermarket melt driven air pump and using that. on my 4.3 i unbolted my lines and threw them out. im going to the junkyard tomorrow to get the lines again. his stock a/c pump has enough pressure to fill a 44 tsl in like 4 minutes. pretty neat.
Jeez give him a break that was a ton of work in one day.
We need details, details, details,
You are going to have a bunch of copycats.![]()
Why won't it go in the smog pump spot? Does it hit the block?
