horn/buzzer
Justin Fleming
Oxford MI
Can someone fresshen my memory. So I am chassing a buzzer on issue, I pulled the horn cap off and the horn wire was just laying there. So I assume someone has been in this steering column. I thought there was a spring, a plastic sleeve thing and some sort of retaininer for the horn wire. Also how does the key work with the buzzer contact? There is the metal piece that slides down in the square hole and then you have the plastic piece with the two copper contact tabs coming off it that goes down there also...
Just dont quite remember.....
