Horn location
Trailhound
Las Vegas NV.
Okay sorry everyone for all the questions. My horn is stuck on so I have pulled the fuse, where is the horn located in my 1980 K5 Blazer.
The title really got my attention though.
Horn is behind the grill on the core support though. :D
Don’t worry about multitude of questions - that’s why this site is so good; the variety of skill sets , talents and interests of all involved basically assures an informed and educated answer. If there is misinformation given it’s usually corrected fairly quickly.
1980 has two horns, one immediately next to each headlight. Visible through the grill. Horn relay is under the steering wheel, and then the steering wheel button closes the ground to activate horns.
Thanks for all the replies.
I'm going go through the steering wheel soon.
Short term, I would unplug the horn relay to see if that stops it. Otherwise, you will have a draw on the battery.
The relay is just above the fuse block.
