euzoa
I pulled apart my column to replace my highbeam switch, low and behold my canceling cam is broken, and when i removed the locking plate it exploded into my lap.
OK, not a big deal order new one and a horn contact kit from lmc.
I get everything back together just fine, up until the horn contact, i understand i have to cut it down, but i figured before i mess with that i will take a bit of with and close the circuit and make sure its working, since i totaled my steering wheel puller.
nothing.
The only thing that didnt go back in was a small spring that looked to have fallen in and not been part of anything. i have power to the fuse, i checked that already.
what are your suggestions?
Also what do i do for a wire from the contact to the horn button?
edit- I didnt remove the plastic from the top of the canceling cam, bet thats it...
Fixed- i managed to lose the contact the hit the bottom of the canceling cam.
nothing.
