mini_mull
OK, I've exhausted all the possibilities I know of, and I'm taking it to my mechanic tomorrow, but I'm hoping you guys can shed some light on my problem before I do.
Here's the history. Over two years ago, right after I bought my burb I replaced the radiator and heater hoses. I had it flushed a year later. It ran at about 190* and life was good. Then in Feb I replaced the hoses, thermostat, t-stat housing and gasket, and flushed everything. Shortly after my heater core started leaking, so I replaced the heater core. It was still running about 190* and life was good. When the weather heated up it started running hotter than usual while idling, so in June I had the fan clutch replaced. It was still getting too hot at idle (220+) so I flushed the system again (which had gotten surprisingly rusty and corroded since Feb) and it still didn't help. I took the radiator to be rodded and repaired and they said it was too far gone, so I installed a new radiator, and also a water pump. It still runs too hot idling on hot days, so I replaced the t-stat again just in case it was sticking. That was yesterday, and today it ran even hotter and the temp climbed faster (230+). My oil pressure also drops when my temps rise, just in case that matters. I also pulled the crakcase cap today to check for bubbles and I couldn't see anything. My dipstick isn't milky either. Since I've replaced every part of the cooling system, I know of some time in the last 6 months and can't see any bubbles in the crankcase, I have no idea what else could be the problem. It runs fine while moving, but idling heat up quickly.
Sorry for the novel, but I wanted to include as many details as possible. Anyone think they can solve my puzzle?
It did take out a ton of crap with it.
