This problem has been occuring for the past 3 years (summers). It only happens when the outdoor temperature is above ~80*F.
The problem is: After about 1-2 hours of constant driving (can be either city or highway driving... i'm not usually driving in the city for 1-2 hours straight...but it does happen) the engine loses power and shuts off within 30 seconds of the first "symptom"
-The engine is a 1990 TBI 350
-A complete cooldown of the vehicle solves the problem.
-If I let it cool down for 5 mintues I can get it to start again and run for another ~10 minutes before it will die again. I usually use that ten minutes after the first "involuntary shut-down" to get to a safe place to let the truck cool down.
Steps I have taken to try and fix the problem:
-New spark plugs / wires
-New ignition module
-New TPS Sensor / O2 sensor
-Coolant flush / fill
Notes:
-Engine temperature is never above normal when this happens
-Again, I could drive for 3 days straight in 60* ambient temperature and this would not happen, but when the temperature is above 80* (roughly) I can COUNT on this happening.
-The new TPS sensor made the biggest difference. I drove from Boulder, CO to Albuquerque, NM last year, and this happened about 20 times on the way down....I replaced the TPS in ABQ, and the problem only occured once on the drive back.
-But now it's back!
Any ideas are welcome!
My last "clutching at straws" guess is that it may be connected with my TBI spacer (gasket issues), because the problem did not start until after I installed the spacer....In the same category, the problems did not start until I moved to high elevation.
I'm planning on a road trip to Alaska as soon as I get a huge bonus, so this needs to get fixed before another three years go by
Notes:
-But now it's back!
. The 5 logs I have left don't show it dying, I guess I will have to drive aorund with the laptop again...however dangerous trying to log / drive / handle a stalled vehicle on the highway may be
