Could someone tell me how the door pin switches are supposed to control the dome lights in the 80's K5's? I only know things are not like they should be now (i.e. they don't work at all), and haven't been since I got this truck.
Should the dome lights always come on when the doors are opened, regardless? Or only when the parking or running lights are on? Or some other setup yet? And if they're supposed to always come on, how do you keep them from doing so, should you want to? As it is, turning the headlight switch all the way counter-clockwise turns the dome lights on permanently from within the cab. That's how it should be, right? And in that mode, door switches should have no effect? Anywhere else on the dial, they should come on? Except maybe when turned all the way clockwise..? I'm just guessing, but it seems reasonable that way.
I've ordered new OEM door pins, and it might just be as easy as swapping the old ones out and cleaning the connectors, but if it's not, I'd wanna get an idea of how things should be before going to work...
