chevyuser74
how big of an aftermarket electric fan would i need? 74 blazer with 350tbi/700r4 with a/c need more info just ask, also any suggestions or extra parts needed when putting one in appreciated
Where do you live? What is your truck setup?
Single fan for me works fine. Secondary is backup, although could be used for AC, whatever. I'd prefer the lightest electrical draw necessary, but that is dependent on radiator efficiency, ambient temps, AC/no AC, engine size, etc. as to "what is enough fan".
Really quite a few variables here, is the Mark VIII dual speed? The Windstars seem to fit pretty well (although they should really cover the entire radiator, but good luck with that when adapting an OEM fan) but I'm not sure what the Mark VIII's look like, although I did see a police Crown Vic fan last time I was at the 'yard, which was pretty massive.
Some MK VIII are dual speed, mine is not so i bought a fan controller.
http://www.stangfix.com/testforum/gallery/5/231_28_06_10_8_17_43_0.JPG
Bottom right is MKVIII fan.
The problem with having manual control of a fan is you need to keep an eye on it. I know many who have forgotten to switch the fan back on high and start overheating because of it.
The fan controller will control to a set temperature for you. A simple toggle can turn the fan on/off completely.
