Well I pulled the motor today, the block casting number is 361959 and my heads Casting numbers are 336781. I will check out my pistons tomorrow to see what they put in there and also hoping to get the front torn down to get the cam information.
Ok I finally got the specs on the camshaft that was in my 454. The shop oopsed and initially gave me the wrong info.
Intake : 204 .268 .455 Exhaust 208 .270 .459. So I guess that's pretty small. I'm still trying to figure out the best camshaft for a 1,400 to 5,400 range to maximize torque and low to midrange power. Thoughts and opinions would be great![]()
I gave mine above....for the few that have rode in my truck, they can attest....it is HEAVY, and it MOVES!
head work is about as important as cam selection I believe...but something in the .525lift and [email protected] duration should work real good with stock 781's.
BBC's love compression and cam, as always you should strive for matched components and your best bet would be to call Comp for some direction.
I have used a .523/.530 cam about a hundred years ago on an otherwise stock 1974 454, it responded very favorably...a dual plane intake, and 1-7/8 headers....no machining, no valve job, no upgrade on the springs...it really woke it up in a Monte Carlo I had.
. What do you know about carb spacers?
